How force to access web server automatically behind cisco 1841 router?
mumtazaly
I have configured Cisco 1841 router. My problem is what if every first time a user opens the browser will display a web page server. My web server ip address is 10.10.1.5.  My router configuration :
hostname mumtaz
enable password mumtaz
enabled secret mumtazaly
access-list 1 permit any
ip nat inside source list 1 interface fastethernet 0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip name-server 8.8.8.8 8.8.4.4
ip nat outside
ip add 192.168.1.2 255.255.255.0
no shutdown
interface fastethernet 0/1
ip nat inside
ip add 10.10.1.1 255.255.255.0
no shutdown
exit
ip dhcp excluded-address 10.10.1.1 10.10.1.5
ip dhcp pool LAN
network 10.10.1.0 /24
default 10.10.1.1
dns 8.8.8.8 8.8.4.4
end
thanks
Hi, you will need a proxy server for redirection .
thanks Syed Siraj Uddin, no proxy server can cisco for redirection using NAT
Well you can do policy base routing to acheive this.
Like you make a access list matching the web traffic originating from the inside and then redirect it to desired server.
But let us know why you want to acheive this?I mean for some authentication or for some other purpose.
Hi Syed Moazzam Ali, not for some authentication, just diplay local website from virtualhost web server
