how i can take ios backup by using tftp ( which software i have to choose ) what is the steps
miada.murad
good morning all
could plz help me to do back up of the ios by using tftp server
what software i have to use
what is the exact steps
waiting for reply
patrick.preuss
if you try a litte google you will find the answers :-)
But anyway
this is how to copy images:
http://www.cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a00800a6744.shtml
tftp server software there are many depends on you platform
so try a search
http://www.google.de/search?q=tftp+windows
http://www.google.de/search?q=tftp+linux
Rest depends on router , software version and server platform. and it is not real complicated ;-)
Patrick
Leo Laohoo
You want regular TFTP backup of your IOS or a one of?
If you want a one off, the command is simple:  copy flash:.BIN tftp://
