How Many HSRP groups can i use with Cat 4507?
diegorgarces
How Many HSRP groups can i use with Catalyst 4507?
Kevin Dorrell
Level 10
Level 10
I don't think there is any limitation, apart from the obvious 255 (or should it be 256?) on each VLAN. (In case you didn't know already, the HSRP groups are independent in each VLAN, so you can re-use the numbers.)
Kevin Dorrell
Luxembourg
Edison Ortiz
