How many OSPF routes does a Catalyst 3750 support?
udo.konstantin
Hi all,
I just want to know how many ospf routes a catalyst 3740 support ?
The cisco doc or datasheets doesn't answer this clearly. Because there is only a statement "unicast routes"!? Does this means all unicast routes (eigrp, ospf....static)
If so, there is a statement for about 10k routes ?!
Any comments ?
Udo
Hi Udo,
maybe you want to check this file:
By the way it is not really a reference the number of routes.. especially with dynamic routing protocols. You should instead define the IGP you are using and the PPS/Mbps that a determined router supports.
Recommendations/limits for OSPF are essentially two:
1) no more than 90 routers per area
2) no more than 1000 routers in the whole domain
Of course you can find domains with 250 routers (i have seen it myself) in one area working perfectly but it is not considered a good practice..
Hope to clarify a little bit
Alessio
PS: The Catalyst 3750 has generally no issues with PPS!!!
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage
Posting
The 3750 can only contain so many routes in hardware, which varies based on model and config.  If hardware resources are exceeded, routing performance can slow to a crawl.
See http://www.cisco.com/en/US/products/hw/switches/ps5023/products_tech_note09186a00801e7bb9.shtml#topic3.
The amount of routes on a Catalyst is also dependent on the choosen SDM-Template. You find some values for routing-entries in the documentation:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/15.0_1_se/configuration/guide/swsdm.html
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
