how may i limit internet bandwidth?
IngRobert0
Hi everyone,
i want to limit the bandwidth for 2 of my public address on my cisco router 4321 , i've tried with this configuration:
class-map match-all INTERNET-2
 match access-group name INTERNET-2
class-map match-all INTERNET-1
 match access-group name INTERNET-1
policy-map INTERNET
 class INTERNET-1
  bandwidth percent 20
 class INTERNET-2
  bandwidth percent 80
policy-map RATE-LIMIT
 class class-default
  shape average 30000000
   service-policy INTERNET
interface GigabitEthernet0/0/0
 description TO ISP
 ip address A.B.C.D 255.255.255.240
 ip nat outside
 negotiation auto
interface GigabitEthernet0/0/1
 no ip address
 negotiation auto
 service-policy output RATE-LIMIT
interface GigabitEthernet0/0/1.5
 description LAN-INTERNET-1
 encapsulation dot1Q 5
 ip address 192.168.100.1 255.255.255.0
 ip nat inside
interface GigabitEthernet0/0/1.10
 description LAN-INTERNET-2
 encapsulation dot1Q 10
 ip address 192.168.200.1 255.255.255.0
 ip nat inside
ip nat inside source list INTERNET-1 interface GigabitEthernet0/0/0 overload
ip nat inside source list INTERNET-2 interface GigabitEthernet0/0/0 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 NEXT-HOP
ip access-list standard INTERNET-1
 permit 192.168.100.0 0.0.0.255
ip access-list standard INTERNET-2
 permit 192.168.200.0 0.0.0.255
By the way, the total bandwidth must be  30 Mbps, could anyone help me?
Hi @IngRobert0
In your policy instead of using bandwidth (which is only a gaurantee of BW at the time on congestion) you should use police to rate-limit the BW usage beyond a threshold. for eg
policy-map test
class test
police rate percent 20 conform-action transmit exceed-action drop
You may chose to specify actual value in bits as oppose to the percentage of BW.
Please mark this post help if you find it useful.
you have applied the service policy to a layer 2 interface. It needs to be applied to the outgoing interface. Have a look at the simplified configuration below.
It is unclear what you mean by two public IP addresses, since you appear to have only one ISP connection. Do you want to limit the amount of bandwidth available for your inside networks ? What is the total bandwidth you have available ? The amount of the shaper depends on the amount of bandwidth you have available. That said, policing or rate limiting should be avoided if possible, better to use shaping:
class-map match-all SUBNET_100_CLASS
match access-group 101
class-map match-all SUBNET_200_CLASS
match access-group 102
policy-map SHAPE_POLICY
 class SUBNET_100_CLASS
  shape average 24000000
 class SUBNET_200_CLASS
  shape average 6000000
 class class-default
  fair-queue
description TO ISP
ip nat outside
negotiation auto
service-policy output SHAPE_POLICY
no ip address
negotiation auto
ip nat inside
ip nat inside
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
no ip http server
access-list 1 permit 192.168.100.0
access-list 1 permit 192.168.200.0
access-list 101 permit ip 192.168.100.0 any
access-list 102 permit ip 192.168.200.0 any
