How to advertise NATed IP to peer via BGP
shahzadliaqat
Hi everyone
May be my problem is very small for most of u people but iam badly stuck with it. any kind of help will really be appreciated
I have my private IP which i cant advertise to MPLS cloud as my remote sites also have same private IP so i NATed it into some other IP and now i want to advertise it to cloud via BGP but it is not advertising it. My router only advertises directly connected IPs or those IPs being learned from IGP but not my virtual NATed IP. here is my important part of code
interface FastEthernet0/0
ip address 10.1.1.22 255.255.255.252
ip nat outside
interface FastEthernet0/1
ip address 192.168.8.0 255.255.255.0
ip nat inside
router bgp 65021
bgp router-id 10.1.1.22
bgp log-neighbor-changes
neighbor 10.1.1.21 remote-as 64517
address-family ipv4
redistribute static
neighbor 10.1.1.21 activate
no auto-summary
no synchronization
network 192.168.171.0 mask 255.255.255.0
exit-address-family
ip nat inside source static network 192.168.8.0 192.168.171.0 /24
If i write 192.168.8.0 instead of 192.168.171.0 while configuring network for bgp, it advertises it but i don't want 8.0 subnet to be advertised. I want 171.0 subnet advertisement.
Any suggestions??
i would be really thankful for any kind of help
regards
shahzad
Jon Marshall
Shahzad
Add this to you router config
ip route 192.168.171.0 255.255.255.0 Null0
For a EBGP peer to advertise a route it must be in the IGP routing table. You don't have that but you are redistributing static so if you add the above static route it will be advertised out.
Jon
Jon
Thank you so much. It has straight away advertised it after i add your mentioned static route. I have been struggling with it since yesterday but u just solved the problem in one click. thanks for your help
regards
shahzad
Shahzad
No problem, glad to have helped.
Jon
