How to allow users access to some websites
ekpesinyang
I have a client with a request that he wants some websites to be view on his network.
Currently all access to www has been block with access list below:
ip nat inside source list 101 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 105.141.22.21
access-list 101 permit ip 192.168.100.0 0.0.0.255 any
access-list 102 permit ip any host 105.141.28.243
access-list 102 permit ip any host 105.141.22.21
access-list 102 permit ip any host 188.125.80.144
access-list 102 permit ip any host 216.58.213.101
access-list 102 permit ip any host 8.8.8.8
access-list 102 permit ip any host 83.143.8.249
access-list 102 permit ip any host 83.143.8.220
websites Like :
yahoo
gmail
gtbank
and many other sites should be allowed.
Please advice me on the configuration.
Thank You.
5 Replies 5
Hello
Require further information
acl 101 is for nat translations
acl 102 is for ????? Where is this applied
What is prohibiting url access  - acl - Fw ?
res
paul
Kind Regards
Paul
URL filtering is usually configured to BLOCK access to certain websites. I am not sure if the below works. It is usually the other way round, you drop the class that matches the URL you want to block, and everything else goes through. I don't know if it works the other way round, to drop the default class. Give it a try:
class map match-any URL_ALLOW_CLASS
 match protocol http host "gmail.com"
 match protocol http host "gtbank.com"
 match protocol http host "yahoo.com"
policy-map URL_ALLLOW_POLICY
 class URL_ALLOW_CLASS
 class class-default
  drop
interface FastEthernet0/0
description LAN Interface
service-policy input URL_ALLOW_POLICY
Hello George,
I have tried your suggestions and it's not working. All sites are still browsing. I noticed that when i type and apply the drop command it will show
"Router(config-pmap-c)#drop
Drop cannot be configured in class-default"
My config details are found below:
Router#sh run
Building configuration...
Current configuration : 1188 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp pool cisco
network 192.168.100.0 255.255.255.0
dns-server 8.8.8.8
default-router 192.168.100.1
lease 0 0 1
class-map match-any URL_ALLOW_CLASS
policy-map URL_ALLOW_POLICY
class class-default
ip address 192.168.0.3 255.255.255.0
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.100.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
clockrate 2000000
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip http server
ip nat inside source list 100 interface FastEthernet0/0 overload
access-list 100 permit ip 192.168.100.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line vty 0 4
login
end
A router is not a good platform for doing URL filtering. If the client really wants to selectively permit only certain web sites then the client should purchase a platform designed for URL filtering, like an ASA with FirePower.
Rick
Rick
Zain Khan
there are two thing which you have clear when you apply ACL.
1. the interface and the device on which you applying
2. In/Out
my suggestion if you want to allow well known websites like Yahoo, Google and Facebook instead of premiting them deny those to whom you want to block. Also share the topology in order to understand your gateway.
because well known websites uses so many IPs if you will permit them the user can able to access the some more websites thru facebook and yahoo
Zain Khan
https://www.linkedin.com/in/forzain/
