How to always keep 3G connection up as backup?
dennis_range
I have many HWIC-3G-HSPA cards as backup connections and I need to keep them up for monitoring purposes. Being a backup connection they get little interesting traffic for them to spring into life but they are the source interface for a tunnel interface (we use DMVPN). The interface still insists on going down. I have even added static routes to the DMVPN hubs over the cellular interface and they still go down. What command do I enter to always keep them up? I had originally used 'dialer idle-timeout 0' and then removed it altogether which the same results. Below is what I have now.
interface Cellular0/1/0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation ppp
dialer in-band
dialer string gsmscript
dialer-group 1
async mode interactive
ppp chap hostname //username//
ppp chap password //password//
ppp ipcp dns request
access-list 1 permit any
dialer-list 1 protocol ip list 1
line 0/1/0
exec-timeout 0 0
script dialer gsmscript
modem InOut
no exec
transport input all
transport output all
rxspeed 7200000
txspeed 5760000
Matteo Comisso
Hi Dennis,
I had the same problem and, thanks to uncle Google, I've found the solution
This is the final config:
Router#sh run
Building configuration...
Current configuration : 2120 bytes
! Last configuration change at 12:04:38 UTC Mon Nov 14 2011
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip name-server 208.67.222.222
ip name-server 208.67.220.220
ip ddns update method ddns
HTTP
  add http://username:password@members.dyndns.org/nic/update?hostname=password@members.dyndns.org/nic/update?hostname=&myip=
  remove http://username:password@members.dyndns.org/nic/update?hostname=password@members.dyndns.org/nic/update?hostname=&myip=
interval maximum 0 1 0 0
chat-script gsm "" "ATDT*99#" TIMEOUT 60 "CONNECT"
license udi pid CISCO2801 sn FCZ102213BX
redundancy
controller Cellular 0/1
interface FastEthernet0/0
ip address 192.168.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
no ip address
ip nat outside
encapsulation ppp
dialer in-band
dialer pool-member 1
ppp chap hostname
ppp chap password 0
interface Cellular0/1/1
no ip address
encapsulation ppp
interface Dialer1
ip ddns update hostname myhostname.dyndns.org
ip ddns update ddns
ip nat outside
encapsulation ppp
dialer pool 1
dialer string gsm
dialer persistent
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 10 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
control-plane
line con 0
line aux 0
line 0/1/0
exec-timeout 0 0
script dialer gsm
login
modem InOut
no exec
rxspeed 7200000
txspeed 2000000
line 0/1/1
no exec
rxspeed 7200000
txspeed 2000000
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Thanks to the "dialer persistent" parameter, that has to be put into the dialer interface, the cellular line is always up!
Matteo
