How to change log time stamp and error detail
gopi_b4u2003
                       When I show diagnostic logs for aWS-C2960G-24TC-L the timestamp only shows the "12w6d". How do I set the log to show the complete time ?
now I have added the command
"service timestamps log datetime localtime"
"service timestamps debug datetime localtime"
Still i am getting the old logs in this format only "12w6d"
Is there anyway to convert the logtime into normal time.
Thanks in Advance
Gopinath.L
vmiller
Level 7
Level 7
You need to set the system clock first.
This is done either through setting the clock on the device itself
or by pointing the device to an NTP server.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_46_se/configuration/guide/swadmin.html
milan.kulik
Level 10
Level 10
I met similar problem several years ago with 3548-XL switches.
I had to reload the switch to make the new log timestamps working that time.
BR,
Milan
No suprise there Milan.
I would suggest our questioner look hard at taking NTP from the
Internet assuming they have no valid NTP source on the inside
of their network. Any reboot tends to whack the clock settings.
