How to change source ip in ip nat translation? Please help
superkingkong
Hi guys,
Some network pros have setup our Cisco 3620 many years back during implementation.
I've just added a new server, with new ip, wanted to change the ip of ip nat translation in this router. Anyone can help?
I did a show run, the config is this;
interface FastEthernet0/0
ip address 57.31.132.116 255.255.255.240
no ip redirects
ip nat outside
no ip route-cache cef
no ip route-cache
no ip mroute-cache
speed 100
full-duplex
standby 222 ip 57.31.132.115
standby 222 priority 105
standby 222 preempt
standby 222 authentication cisco222
standby 222 name hsrp-122
interface FastEthernet0/1
description SITA External services NAT Trunk
no ip address
no ip route-cache
no ip mroute-cache
speed 100
full-duplex
interface FastEthernet0/1.170
description AODB inside
encapsulation dot1Q 170
ip address 10.110.10.101 255.255.128.0
no ip redirects
ip nat inside
no ip route-cache
no ip mroute-cache
standby 170 ip 10.110.10.100
standby 170 priority 105
standby 170 preempt
standby 170 authentication cisco170
standby 170 name aodb
standby 170 track FastEthernet0/0
interface FastEthernet0/1.171
description BHS
encapsulation dot1Q 171
ip address 10.10.10.101 255.255.0.0
no ip redirects
ip nat inside
no ip route-cache
no ip mroute-cache
standby 171 ip 10.10.10.100
standby 171 priority 105
standby 171 preempt
standby 171 authentication cisco171
standby 171 name bhs
standby 171 track FastEthernet0/0
ip nat Stateful id 1
     redundancy hsrp-122
         mapping-id 10
ip nat inside source static 10.110.10.33 57.31.132.121 redundancy hsrp-122
ip nat inside source static 10.10.10.50 57.31.132.122 redundancy hsrp-122
ip nat inside source static 10.110.10.7 57.31.132.119 redundancy hsrp-122
ip nat inside source static 10.10.10.51 57.31.132.123 redundancy hsrp-122
ip nat inside source static 10.110.10.4 57.31.132.120 redundancy hsrp-122
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 57.31.132.113
My cisco knowledge is very basic. I would like to change this line
or if can, add another line...
My new ip is 10.110.10.123
but i don't have control over 57.31.132.0 network. 10.110.10.0 belongs to us.
so, either change to 10.110.10.123 57.31.132.121 or add another new line like 10.110.10.123 57.31.132.124 ?
Not sure it will impact that network.
Appreciate if anyone could help. thanks.
Added in
Config Mode
route (config)# ip nat inside source static (local IP) (Public IP)
Make Sure Local IP that you give its gateway must be Router Inside Interface IP
**Please Rate All Helpful Posts**
Jawad
5 Replies 5
Giuseppe Larosa
This is lilkely the best option as it would have no impact on existing NAT rules
Hope to help
Giuseppe
Thanks for the suggestion.
The next step is.. how can I do it...
Can I copy out the running-config to tftp and edit the text file - add that new line, and reupload to the router? copy tftp to running-config?
or do I have to issue those commands in command line? is so, may i know the steps?
thank you
the new line can be added to the configuration file on the fly if you know the enable password
connect to the router either by telnet or SSH or via console
at router prompt type enable followed by enter
router> enable:
at new prompt enter the enable password
when prompt changes to
router#
configure terminal
router(config)#
!at this point you can insert the line of the new NAT statement
! after that you exit from configuratiion mode
router(config)# exit
! last operation is to save the running configuration
router# wr mem
Hope to help
Giuseppe
Added in
Config Mode
Jawad
THANK YOU!!
