How to configure ACL for internet facing edge router port?
CiscoBrownBelt
Level 6
Level 6
What is the best way to create an ACL to be used on an internet facing edge port to keep the logs down when packets are denied from devices not permitted according to the ACL? Shall I just enter permit statements allowing for internal to external comms then block everything else?
Hello
I would be concerned with inbound traffic then outbound on a internet facing port.
For egress you can as shown allow any traffic originating fro you internal network or specific subnets and then deny everything else.
For ingress, I would suggest deny everything other then bi directional traffic such a routing protocols.
So do that you can implement a software ios feature such as CBAC, which will ONLY by default allow return traffic initiated from inside you network back in.
Simple CBAC configuration would be.
ip inspect name CBAC tcp
ip inspect name CBAC udp
ip inspect name CBAC icmp
ip access-list extended WAN
permit ospf any any
deny  ip any any
ip access-list extended LAN
permit ip x.x.x.0 0.0.0.255 any
deny  ip any any log-input  <-more granular for the ace entries
interface x/x
description WAN Interface (ospf)
ip access-group WAN in
interface x/x
description LAN Interface
ip inspect CBAC in
ip access-group LAN in
res
Paul
Kind Regards
Paul
Julio E. Moisa
Your current ACL will allow the access just to the authorized entries, by default there is an implicit deny entry at the end of the ACL, now you can include a deny at the bottom to log the deny.
ip access-list 100 permit ip host 1.1.1.1 any
ip access-list 100 deny ip any any log
interface g0/0
ip access-group 100 out
The following link can be useful
https://www.cisco.com/c/en/us/about/security-center/access-control-list-logging.html
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hello
permit ospf any any
deny  ip any any
interface x/x
interface x/x
ip inspect CBAC in
res
Paul
Kind Regards
Paul
Perhaps there is something for this thread that I am not understanding correctly. Julio provides a good suggestion which answers a question about how to create log entries when something is denied. And Paul provides a good suggestion about CBAC which answers a question about good ways to configure protection for the router. But as I understand the post it is asking a different question. It seems to me that the most important part of the original post is this "to keep the logs down when packets are denied". And the answer to that is simply to not use the log parameter on entries in the ACL which deny packets. If I am not understanding correctly then please help me understand better.
Rick
Rick
Yes you are on spot. I DO want to keep the logs down and that ties in with best practices for ACLs or configs to be used on internet/WAN ports. I DON'T want a long ACL (adding deny statements for suspicious addresses that arise, etc.) and thought I would just alllow what needs to be allowed then block everything else.
