how to configure and join with wlc 2112 ?
fb_webuser
Level 6
Level 6
air lap 1041n
i have air lap 1041n(soft version 12) and wlc 2112
i dont have dhcp server perhaps i use tftpd32 to act as a dhcp server.
my problem is
1. i have configured the wlc 2112 and it's ip is :172.25.1.1
2. i cant configure the air lap 1041n. when i enter the cli mode the following message comes ****continuously***:
Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar 1 01:44:11.310: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
3. my question is how to stop this continuous mgs ?
4. how can i assign an ip to my AP ?
5. how can i join my AP with MY wlc ?
i am working in my office for Research and design purpose and im New in this field.
i have to show my office that i can control two ari lap 1041n-k9 with my WLC 2112 and my laptop's wifi and cellphone's wifi are able to get connected with the Access points.
a quick reply will be helpful
thank you
ARIQ IBNE AZIZ
Posted by WebUser Ariq Aziz
Leo Laohoo
Console into the WAP and in enable mode use this command:  capwap ap ip address
After you have given an IP address to your WLC, just make sure the WAP can ping the Management IP address of your WLC.  If it can't then make sure the WLC and the WAP are in the same VLAN and the same subnet.
If the WAP can ping the WLC it would take less than a minute for the WAP to join the WLC.  If not then try the command "capwap ap controller ip address ".
Make sure your WLC is running 7.0.X firmware.
