how to configure ipsla monitor in IOS XR Software, Version 4.2.3?
gneatmach
I don't see ipsla commands in IOS XR Software, Version 4.2.3. Any other ways to detect ethernet WAN links to trigger HSRP on ASR 9000 series routers? I don't even see track commands.
RP/0/RSP0/CPU0:grx-rtr2(config)#ip
iphc  ipv4  ipv6
RP/0/RSP0/CPU0:grx-rtr2(config)#t
tacacs-server  tacacs  taskgroup  tcam
tcp            telnet  template   tftp
/Tej
Bilal Nawaz
1. configure
2. track track-name
3. type line-protocol state
4. interface type interface-path-id
5. exit
6. (Optional) delay {up seconds|down seconds}
7. Use one of the following commands:
end
commit
Please see if the commands in this link are available to you on cli
http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.2/system_management/configuration/guide/b_sysman_cg42asr9k_chapter_01110.html
And then to use the track command in HSRP
hsrp [group-number] track type interface-path-id [priority-decrement]
I'm not sure if these are required.
As demonstrated here:
RP/0/0/CPU0:router(config)# router hsrp
RP/0/0/CPU0:router(config-hsrp)# interface TenGigE 0/2/0/1
RP/0/0/CPU0:router(config-hsrp-if)# hsrp track TenGigE 0/1/0/1
RP/0/0/CPU0:router(config-hsrp-if)# hsrp track TenGigE 0/3/0/1
RP/0/0/CPU0:router(config-hsrp-if)# hsrp preempt
RP/0/0/CPU0:router(config-hsrp-if)# hsrp ipv4 192.92.72.46
http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r3.9/addr_serv/command/reference/irasr9khsrp.html#wp999728
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Bilal Nawaz
1. configure
2. track track-name
5. exit
end
commit
Hope this helps
There were below packages missing in ASR9001 router and hence I could not find track commands. After installing below packages I could see track and ipsla commands.
  asr9k-mgbl-supp-4.2.3
  iosxr-mgbl-4.2.3
  asr9k-mgbl-p-4.2.3
router hsrp
interface GigabitEthernet0/0/1/0
  address-family ipv4
   hsrp 1 version 1
    preempt
    address *******
   hsrp 2 version 1
    preempt
    priority 110
    address *******
    track object WAN 15
track WAN
type rtr 1 reachability
ipsla
operation 1
  type icmp echo
   destination address *******
   frequency 60
schedule operation 1
  start-time now
  life forever
/Tej
