How to configure Lease line and ADSL
phnhuong
Dear Sir/Madam
I have network as follows:
LAN---Fire Wall--Router 1841--
-----Lease line
I
-----ADSL
I want traffic IN include:email(smtp,POP3), VPN, Web mail... use lease line and traffice OUT include: access web,FTP,yahoo chat...use ADSL.
Now I configured both lease line and ADSL Up but all traffic alway use lease line.
can you help me!
Thanks a lot
version 12.3
hostname VT
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
username aabb privilege 15 secret 5 $1$A7lA$WX3Z6vi/Ja84pec94rCcj.
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip domain name vti.com
ip name-server 203.162.4.12
ip name-server 203.113.131.11
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
no ftp-server write-enable
interface FastEthernet0/0
description connected to EthernetLAN
ip address 222.255.74.110 255.255.255.248
ip nat inside
ip tcp adjust-mss 1452
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
description connected to VDC
ip address 222.255.79.249 255.255.255.252
ip nat outside
interface ATM0/1/0
description connected to Viettel
ip address dhcp hostname viettel
ip helper-address 203.113.131.11
no atm ilmi-keepalive
dsl operating-mode auto
pvc 8/35
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname 038721c
ppp chap password 0 49bc60
ppp pap sent-username 038721c
password 0 49bc60
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0/0
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip http authentication local
ip http timeout-policy idle 600 life 86400 requests 10000
dialer-list 1 protocol ip permit
snmp-server community string RO
snmp-server enable traps tty
control-plane
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
line vty 5 15
privilege level 15
login local
end
in order to manipulate the traffic flow, your best option is probably to implement policy routing, where you tell the router to send certain traffic out one interface, and other traffic out another interface.
The access lists that define which traffic has to go where can become a little tricky, depending on what you want, here is what I think the configuration should look like, based on the information you have provided:
ip policy route-map TRAFFIC
route-map TRAFFIC permit 10
match ip address 101
set interface Serial0/0/0
route-map TRAFFIC permit 20
match ip address 102
set interface Dialer1
route-map TRAFFIC permit 30
access-list 101 permit tcp any any eq smtp
access-list 101 permit tcp any eq smtp any
access-list 101 permit tcp any any eq pop3
access-list 101 permit tcp any eq pop3 any
access-list 102 permit tcp any any eq www
access-list 102 permit tcp any any eq domain
access-list 102 permit tcp any any eq ftp
access-list 102 permit udp any any range 5000 5010
access-list 102 permit tcp any any range 5000 5001
As I said, the access list might become tricky. Outlook Web Access, for example, use the common WWW port 80 as well. Also, you will need to find out which ports your VPN is using, and add those to the access list.
By the way, UDP ports 5000 thru 5010 are used by Yahoo, if those don't work, it will try TCP port 5000 thru 5001.
Let me know if you run into trouble with this, or if you need more help...
GP
