How to configure Multiple DHCP with internet access
cool01
I would like to ask some help to fix my configuration by using Multiple DHCP with internet access.
Currently my configuration below is connected to multiple dhcp unfortunately unsuccessful Internet access.
Current configuration : 1449 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5 $1$nrgd$KqCZrWkVWFUIV/4V5DNRn/
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp excluded-address 192.168.20.1 192.168.20.10
ip dhcp pool vlan10
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 103.225.36.226 103.225.36.238
ip dhcp pool vlan20
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
interface FastEthernet0/1.10
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
ip nat outside
interface FastEthernet0/1.20
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
ip nat inside
username fair password 0 fairship
interface FastEthernet0/0
 description Link_to_ISP$ETH-LAN$
 ip address 103.225.36.242 255.255.255.252
ip nat inside
 speed 100
 full-duplex
 description Link_to_LAN$ETH-LAN$$ES_LAN$
ip nat outside
no ip address
ip nbar protocol-discovery
 speed 100
 full-duplex
 service-policy output DROP
interface Serial0/0/0
 no ip address
 shutdown
 clock rate 2000000
ip classless
ip route 0.0.0.0 0.0.0.0 103.225.36.241
ip http server
control-plane
line con 0
 password fairshipping
 logging synchronous
 login
line aux 0
line vty 0 4
 logging synchronous
 login local
end
2 Accepted Solutions
I have made a few additions to your configuration (in bold):
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
ip cef
ip dhcp pool vlan10
ip dhcp pool vlan20
ip nat inside
ip nat inside
ip nat outside
speed 100
full-duplex
ip nat inside
no ip address
speed 100
full-duplex
no ip address
shutdown
clock rate 2000000
ip nat inside source list 1 interface FastEthernet0/0 overload
ip classless
access-list 1 permit 192.168.10.0
access-list 1 permit 192.168.20.0
ip http server
control-plane
line con 0
logging synchronous
login
line aux 0
line vty 0 4
logging synchronous
login local
do your clients get an IP address ? You might want to add:
interface FastEthernet0/17
switchport access vlan 10
description access-port
spanning-tree portfast
to all the access ports.
17 Replies 17
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
ip cef
ip dhcp pool vlan10
ip dhcp pool vlan20
ip nat inside
ip nat inside
ip nat outside
speed 100
full-duplex
ip nat inside
no ip address
speed 100
full-duplex
no ip address
shutdown
clock rate 2000000
ip classless
ip http server
control-plane
line con 0
logging synchronous
login
line aux 0
line vty 0 4
logging synchronous
login local
I already applied the configuration unfortunately still not working, but i try it again tomorrow. Thanks for your response i hope you can reply my inquiries until i success this configuration. I also include my Switch config below.
Switch
Building configuration...
Current configuration : 5369 bytes
! Last configuration change at 14:25:32 GMT+8 Tue Aug 18 2015
! NVRAM config last updated at 14:13:48 GMT+8 Tue Aug 18 2015
version 15.0
no service pad
hostname fair_switch
boot-start-marker
boot-end-marker
enable password f@1r
no aaa new-model
clock timezone GMT+8 8 0
crypto pki trustpoint TP-self-signed-2967729024
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2967729024
 revocation-check none
 rsakeypair TP-self-signed-2967729024
crypto pki certificate chain TP-self-signed-2967729024
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32393637 37323930 3234301E 170D3933 30333031 30303030
  35385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 39363737
  32393032 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100A994 D09FA408 93DB36BB EB73F0E5 7B4E8FEE A19B52D4 345628F8 C1E7967D
  1E4B5AFD B5B4CB26 9E80D684 8CE610CA A2313E38 04E053BC 21CC4660 B7694029
  7E8FA283 65B72EFE 6D884BF1 1111F005 92734180 34B7C4F8 35F7DFD8 41D40037
  668EEB24 23430096 8AF4C5B7 926E09A8 0C17E30B CD95A0DE 3F68D3EE 2FE75B5B
  0A710203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 143DD2B4 5967CBE7 F732A40D 05A6F94D 1564072A 54301D06
  03551D0E 04160414 3DD2B459 67CBE7F7 32A40D05 A6F94D15 64072A54 300D0609
  2A864886 F70D0101 05050003 8181009F D800E049 CEC8977B F8C672B6 AB6F791E
  5DD70B9D 1BA8E7D5 65326C3A 32CE5A19 1328B4C7 AEEF2386 E787B996 DF904E86
  AC347DF1 0BAA1B8C 8B75667C 8A990367 1E8C2DC2 0C5789C4 214717C2 DCD50244
  5B30FD76 3FB9E159 2B472F6A 3509676C 5FCEACD7 F20FDC10 9FE3B1A5 1EAA223E
  24F57C5E E3CF6D35 743F50F1 2F6E96
        quit
spanning-tree mode pvst
vlan internal allocation policy ascending
 no ip address
 shutdown
switchport mode trunk
 speed 100
 duplex full
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface FastEthernet0/25
interface FastEthernet0/26
interface FastEthernet0/27
interface FastEthernet0/28
interface FastEthernet0/29
switchport access vlan 20
interface FastEthernet0/30
interface FastEthernet0/31
interface FastEthernet0/32
interface FastEthernet0/33
interface FastEthernet0/34
interface FastEthernet0/35
interface FastEthernet0/36
interface FastEthernet0/37
interface FastEthernet0/38
interface FastEthernet0/39
interface FastEthernet0/40
interface FastEthernet0/41
interface FastEthernet0/42
interface FastEthernet0/43
interface FastEthernet0/44
interface FastEthernet0/45
interface FastEthernet0/46
interface FastEthernet0/47
interface FastEthernet0/48
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip http server
ip http secure-server
snmp-server community bl4ckf1b37 RO 99
snmp-server location FairShipping, Malate, Manila
snmp-server contact noc@blackfibersolutions.com
snmp-server chassis-id Cisco 2960
snmp-server enable traps tty
line con 0
line vty 0 4
 password fairs
 login
line vty 5 15
 login
end
Thanks for your response, i will do your suggestion for my problem. I hope you still response my inquiry until i success this case.
Thank you again
My client got IP address even without spanning-tree portfast but as per your advise i include the spanning-tree portfast. Unfortunately upon applying this config below i still having bad result. Please see below my config for Router and Switch. And please correct my config.
ROUTER
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
ip cef
ip dhcp pool vlan10
ip dhcp pool vlan20
ip nat outside
ip nat outside
username fairs password 0 fairs
policy-map DROP
 class BLOCKED
   drop
 description Link_to_BlackFiber$ETH-LAN$
ip nat inside
 speed 100
 full-duplex
ip nat outside
no ip address
 speed 100
 full-duplex
 no ip address
 shutdown
 clock rate 2000000
ip classless
ip http server
control-plane
line con 0
 password fairs
 logging synchronous
 login
line aux 0
line vty 0 4
 password fairs
 logging synchronous
 login local
end
 SWITCH
Switch
version 15.0
no service pad
boot-start-marker
boot-end-marker
enable password f@1rs
no aaa new-model
        quit
 no ip address
 shutdown
 speed 100
 duplex full
interface Vlan1
ip http server
snmp-server location FairS, Malate, Manila
line con 0
line vty 0 4
 password fairs
 login
line vty 5 15
 login
end
the 'ip nat inside' and 'ip nat outside' statements on your router are reversed. Change them to what I marked in bold below:
ROUTER
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
ip cef
ip dhcp pool vlan10
ip dhcp pool vlan20
ip nat inside
ip nat inside
policy-map DROP
class BLOCKED
drop
ip nat outside
speed 100
full-duplex
ip nat inside
no ip address
speed 100
full-duplex
no ip address
shutdown
clock rate 2000000
ip classless
ip http server
control-plane
line con 0
password fairs
logging synchronous
login
line aux 0
line vty 0 4
password fairs
logging synchronous
login local
end
After configuration I ping my DNS 8.8.8.8 and 103.225.36.238 using telnet all has success rate 100 but my network connection still limited, i noticed while ping the DNS using cmd my result is "request time out" unlike before "unreachable". Also in my research, I recognized that our configuration for router/switch are correct but i can't understand the configuration still no internet access?
 =ROUTER=
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
ip cef
ip dhcp pool vlan10
dns-server 8.8.8.8
ip dhcp pool vlan20
dns-server 8.8.8.8
ip nat inside
ip nat inside
ip nat outside
 speed 100
 full-duplex
ip nat inside
no ip address
 speed 100
 full-duplex
 no ip address
 shutdown
 clock rate 2000000
ip classless
Access-list 1 permit 192.168.10.0
Access-list 1 permit 192.168.20.0
ip http server
control-plane
line con 0
 password fairs
 logging synchronous
 login
line aux 0
line vty 0 4
 password fairs
 logging synchronous
 login local
end
=SWITCH=
version 15.0
no service pad
boot-start-marker
boot-end-marker
enable password f@1rsh1pp1ng
no aaa new-model
        quit
 no ip address
 shutdown
 speed 100
 duplex full
interface Vlan1 (telnet)
ip address 103.225.36.250 255.255.255.252
ip http server
line con 0
line vty 0 4
 password fairs
 login
line vty 5 15
 login
end
I share the details i had so can easily understand what i want supposed to do in my network.
1. Router= 1841 (1800 series)
2. Switch= 2960SF Catalyst
3. I need a separated network with both INTERNET ACCESS.
       a. Network 1 = 192.168.10.1
       b. Network 2 = 192.168.20.1
4. ISP Details(modem) - Direct
       IP Address: 103.225.36.242
       SM: 255.255.255.252
       GW: 103.225.36.241
5. Router to Modem=fa0/0, Router to Switch=fa0/1
the config looks good. If you can ping 8.8.8.8 you (obviously) have Internet access. What is the output of 'ipconfig /all' from one of the PCs on Vlan 10 or Vlan 20 ?
But if you ping 8.8.8.8 or 103.225.36.238 you have result "Request Time Out" also i noticed while checking the packet sent/received the sent was simultaneously responded unlike received has no responded. even google.com has rto result.
ipconfig /all for Vlan10
192.168.10.11
255.255.255.0
192.168.10.1
8.8.8.8
103.225.36.238
ipconfig /all for Vlan20
192.168.20.11
255.255.255.0
192.168.20.1
8.8.8.8
103.225.36.238
you have this configured:
Can you ping 103.225.36.241 from your router ?
After configuring please see the below ping result for 8.8.8.8, 103.225.36.238, 103.225.36.241, 103.225.36.242. What do you say about this result?
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 48/48/48 ms
Sending 5, 100-byte ICMP Echos to 103.225.36.238, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
Sending 5, 100-byte ICMP Echos to 103.225.36.241, timeout is 2 seconds:
Sending 5, 100-byte ICMP Echos to 103.225.36.242, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
I was thinking the IP Address provided by our ISP is not allowed for DHCP Server maybe because the IP Address provided use for static IP address per workstation. Our current configuration having installed Static IP Address due to the 103.225.36.242 was distributed to 30 usable IP Addresses and but the installed static ip address we are using please see this below.
IP: 103.225.37.131 - my pc
SM: 255.255.255.224
GW: 103.225.37.129
DNS1:103.225.36.238
DNS2:103.225.36.226
Current Configuration (Static IP Address per workstation)
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
ip cef
ip name-server 103.225.36.238
ip name-server 103.225.36.226
ip name-server 8.8.8.8
 speed 100
 full-duplex
 ip address 103.225.36.249 255.255.255.252 secondary
 ip address 103.225.37.129 255.255.255.224
 speed 100
 full-duplex
 no ip address
 shutdown
 clock rate 2000000
ip classless
ip http server
control-plane
line con 0
 password fairs
 logging synchronous
 login
line aux 0
line vty 0 4
 password fairs
 logging synchronous
 login local
end
if these are routable public IP addresses of course you can statically assign them to your host. The only limitation is that the number of hosts is now limited to the number of public IP addresses you have available.
