How to configure nat across vpn tunnel?
Simon Bown
I have set up a VPN ipsec tunnel to a customer for a proof of concept.
Our server address is 172.0.0.167 but they want to 'see' our server as 172.29.63.5. I have set up static NAT so they see the address they want.
As this NATed address needs to go across the tunnel I am unsure how to set up the config. I am using a 1841 router and no firewall.
Below is what I have tried but quite sure it is not correct as it doesn't seem to work. The tunnel comes up and NAT translations can be seen but do not show the desired addresses.
Router#sh ip nat tran
Pro Inside global      Inside local       Outside local      Outside global
icmp 172.29.63.5:1     172.0.0.167:1      192.168.0.10:1     192.168.0.10:1
tcp 172.29.63.5:51272  172.0.0.167:51272  192.168.0.15:80    192.168.0.15:80
tcp 172.29.63.5:51273  172.0.0.167:51273  192.168.0.100:5501 192.168.0.100:5501
tcp 172.29.63.5:51274  172.0.0.167:51274  192.168.0.100:5501 192.168.0.100:5501
Any help is greatly appreciated.
ip nat pool POOL1 89.21.228.173 89.21.228.173 netmask 255.255.255.192
ip nat inside source list 7 pool POOL1
ip nat inside source static 172.0.0.167 172.29.63.5
access-list 7 permit 172.0.0.0 0.0.0.255
access-list 7 permit 172.31.0.0 0.0.63.255
access-list 7 permit 172.29.0.0 0.0.63.255
Simon Bown
I still have a problem. Is there anyone who can help?
crypto isakmp policy 5
encr aes 256
authentication pre-share
group 5
crypto isakmp key All address 194.154.190.*
crypto ipsec transform-set Router-IPSEC esp-aes 256 esp-sha-hmac
crypto map ADAM_CMAP_1 1 ipsec-isakmp
description Tunnel to Test
set peer 194.154.190.*
set transform-set Router-IPSEC
set pfs group5
match address 100
interface Loopback1
ip address 172.29.63.0 255.255.192.0
interface FastEthernet0/0
ip address 89.21.228.173 255.255.255.192
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 172.0.0.224 255.255.255.0
ip nat inside
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip route 172.31.0.0 255.255.192.0 89.21.228.129
ip route 172.31.37.175 255.255.255.255 89.21.228.129
ip route 172.31.38.132 255.255.255.255 89.21.228.129
ip route 172.31.38.230 255.255.255.255 89.21.228.129
ip route 194.154.190.* 255.255.255.255 89.21.228.129
ip http server
ip http authentication local
ip http secure-server
ip nat pool allianz 172.29.63.5 172.29.63.5 netmask 255.255.192.0
ip nat inside source list 107 pool all
ip nat inside source route-map ALL interface FastEthernet0/0 overload
ip access-list extended NAT
deny   ip host 172.0.0.167 172.31.0.0 0.0.63.255
permit ip 172.0.0.0 0.0.0.255 any
permit ip host 172.0.0.167 172.31.0.0 0.0.63.255
permit ip host 172.29.63.5 any
permit ip host 172.0.0.167 any
permit ip any host 172.0.0.167
permit ip any host 172.29.63.5
access-list 100 permit ip 172.31.0.0 0.0.63.255 172.29.0.0 0.0.63.255
access-list 100 permit ip any host 172.29.63.5
access-list 100 permit ip 172.29.0.0 0.0.63.255 any
access-list 107 permit ip host 172.0.0.167 172.31.0.0 0.0.63.255
route-map ALL permit 10
match ip address NAT
Simon
You have a number of NAT statements, are they all needed ?
What are the remote IPs at the other end of the VPN tunnel ?
Jon
Hello Jon,
Thanks for your reply.
I have found that the problem was caused by the firewall at our customer's site.
