07-28-2010 04:26 AM - edited 03-04-2019 09:13 AM
Hi all experts,
i want to know about supervisor engine redundancy for actvie switch & standby switch. In my work , there has two catalyst 4503E switchs, all features( include IOS version) are same, my IOS version is 12.1(20)EW, and hardware (supervisor engine II plus WS-X4013+ ) is also assembly on chasis.
One switch is operated now and others is still as spare. Now i want to configure one switch is active switch and 2nd is as standby , when primary fail, standby work as primary. So i try to configure from config mode, type " show redundancy " , but "it's unrecognized command" msg apperared and no sign for redundancy see. In privilege mode, i type " show module " , i saw the following.
s4503#sh module
Chassis Type : WS-C4503
Power consumed by backplane : 10 Watts
Mod Ports Card Type Model Serial No.
1 2 1000BaseX (GBIC) Supervisor(active) WS-X4013+ JAE07470JAD
2 18 1000BaseX (GBIC) WS-X4418-GB JAE07440BWU
3 48 10/100/1000BaseTX (RJ45) WS-X4448-GB-RJ45 JAE08533D4L
M MAC addresses Hw Fw Sw Status
1 000e.38d3.5740 to 000e.38d3.5741 2.0 12.1(19r)EW 12.1(20)EW, EARL Ok
2 000d.bcf6.58c8 to 000d.bcf6.58d9 1.1 Ok
3 0012.dade.4450 to 0012.dade.447f 1.1 Ok
s4503- #conf t
Enter configuration commands, one per line. End with CNTL/Z.
SR4503-YGN-133-1(config)#sh redun ?
% Unrecognized command
S4503 (config)#sh redun
S 4503 #sh ver
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-I9K2S-M), Version 12.1(20)EW,
EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Wed 22-Oct-03 23:03 by kellmill
Image text-base: 0x00000000, data-base: 0x0106B818
ROM: 12.1(19r)EW
Dagobah Revision 86, Swamp Revision 3
S 4503- uptime is 33 weeks, 6 days, 5 hours, 33 minutes
System returned to ROM by reload
System restarted at 12:18:49 UTC Thu Dec 3 2009
System image file is "bootflash:cat4000-i9k2s-mz.121-20.EW.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C4503 (XPC8245) processor (revision 4) with 262144K bytes of memory.
Processor board ID FOX07450450
Last reset from Reload
15 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
68 Gigabit Ethernet/IEEE 802.3 interface(s)
511K bytes of non-volatile configuration memory.
so i don't know how to continue to be complete my mission. Moreover i worry for error occuring while configure two switchs for redundant.
After redundant, it can overlap all dynamic routing information from primary to secondary when primary is failure?
plz help me, step by step guide. thanks
07-28-2010 01:00 PM
I'm afraid the 4503-E does not support redundant supervisors.
http://cisco.biz/en/US/products/ps9295/index.html
HTH,
M
