How to configure VDSL
Dossos001
Hello everyone
I have a new cisco router 887va-k9 how can I configure VDSL
someone can help me please it is SOS
my Best regard
Dosso
Francesco Molino
Let's assume your lan interface is g0/0 and wan interface is g0/1. Also I assume your LAN subnet is 192.168.1.0/24.
Below a sample config:
interface g0/1
no ip address
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface g0/0
ip nat inside
interface Dialer1
description ADSL Connection
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username USERNAME password PASSWORD
ppp chap hostname USERNAME
ppp chap password 0 PASSWORD
ppp ipcp dns request accep
dialer-list 1 protocol ip permit
Ip access-list extended NAT
 permit ip 192.168.1.0 0.0.0.255 any
Ip nat inside source list NAT inter dialer 1 overload
Ip route 0.0.0.0 0.0.0.0 dialer 1
Sorry if there are typo issue I'm typing it through my mobile.
PS: Please don't forget to rate and mark as correct answer if this solved your issue
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
interface g0/1
no ip address
pppoe enable
no cdp enable
interface g0/0
ip nat inside
interface Dialer1
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
Francesco
Thanks a lot for your help . this is my show ip interface br in  below
I dont understand which configuration can i do to configure  ATM0 ?
I try to do what you wrote to me
but The problem is I can not sign ip addr in interface because it is on L2
what can I do ?
i got my CCNA few month ago but I never saw this can of Router with all is Interface are in L2
Router#sh ip int br
Interface                            IP-Address OK?     Method Status                 Prot
ATM0                                  unassigned          YES NVRAM down            down
ATM0.1                              unassigned            YES unset down               down
Ethernet0                           unassigned            YES NVRAM up                down
FastEthernet0                    unassigned            YES unset up                    down
FastEthernet1                    unassigned            YES unset up                    down
FastEthernet2                     unassigned            YES unset up                   down
FastEthernet3                     unassigned            YES unset up                   down
Vlan1                                 unassigned            YES NVRAM down            down
Router#
so please if you can help me to solve this problem
My Best Regard
For ATM interface, please follow this step by step documentation :
http://www.cisco.com/c/en/us/support/docs/long-reach-ethernet-lre-digital-subscriber-line-xdsl/asymmetric-digital-subscriber-line-adsl/71119-adslguide-pppoe-dynmcstep.html
Francesco
Dossos001
Hello supportlan
Thanks very must for your help. configuration  it work with VDSL not with ADSL
