How to configure VOIP to switch 3750
rakesh4
We have 3750 switch and 40 VOIP and what is the configuration made on switch.
VOIP Model is 7941 CISCO
which 3750 do you have ? The 3750X ? The sample config below uses tthe default Vlan for voice traffic:
interface gigabitethernet1/0/1
mls qos trust cos
switchport voice vlan dot1p
If you have a separate voice Vlan, the config would be:
mls qos trust cos
switchport voice vlan x
The 3750X also has the option to detect Cisco IP Phones, using the interface command 'switchport voice detect cisco-phone'.
Check the link below for details:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_55_se/configuration/guide/3750xscg/swvoip.html
Catalyst 3750 Series PoE-48 Switch
