How to configure VPN ( Client to switch) in cisco catalyst 3750 series switch.
bharath.mv
   Please help me to configure vpn in cisco catalyst 3750 series switch.
   Please find the below software version,
Switch#sh ver
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(52)SE, RELEAown
SE SOFTWARE (fc3)8 unassigned
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 25-Sep-09 08:32 by sasyamal0/19 unassigned YES unset down
Image text-base: 0x01000000, data-base: 0x02B00000
F
ROM: Bootstrap program is C3750 boot loaderet down down
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE21 unassigned YES unset
This product contains cryptographic features and is subject to United YES unset down down
States and local country laws governing import, export, transfer and unassigned YES unset down down
FastEthernet2/0/26 unassigned YES unset down
FastEthernet2/0/27 unassigned YES
FastEthernet2/0/28
compliance with U.S. and local country l
If you require further assistance please contact us by sending email tostEthernet2/0/33 unassigned YES unset down d
export@cisco.com.
cisco WS-C3750-48TS (PowerPC405) processor (revision N0) with 131072K bytes of m YES unset down down
emory.
Processor board ID CAT1113NJGNhernet2/0/35 unassigned
Last reset from power-on
1 Virtual Ethernet interfacesigned YES unset down
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
FastEthernet2
The password-recovery mechanism is enabled. down
512K bytes of flash-simulated non-volatile configuration memory.2/0/38 unassigned YES unset down down
Base ethernet MAC Address : 00:1B:8F:B8:A2:00
Motherboard serial number : CAT111359Y4
Power supply serial number : DTH1105B29Q
Model revision number : N0
Motherboard revision number : B0
Model number : WS-C3750-48TS-S
System serial number : CAT1113NJGN
SFP Module assembly part number : 73-7757-03
SFP Module revision Number : A0
SFP Module serial number : CAT11115NB9
Top Assembly Part Number : 800-25854-02
Top Assembly Revision Number : F0
Version ID : V05
CLEI Code Number : CNMV300CRE
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 2 52 WS-C3750-48TS 12.2(52)SE C3750-IPBASEK9-M
Configuration register is 0xF
Milos Megis
Level 3
Level 3
as long as I know, switch doesn´t support VPN feature.
You need router with proper IOS or license for that. Or better is use firewall for that purpose.
