How to Configure WIC Interface
granitenet
I have configured a WIC interface for our Cisco 3600 router. But it reads "Serial/3:0 is up, line protocal is down" - I have had the checked out and have been told that the router is the issue. I have checked the other end of the T1 and find they are having the same issue. Here is what my Interface looks like:
interface Serial1/3:0
description NISC
bandwidth 1544
ip address 192.168.98.2 255.255.255.252
encapsulation ppp
This matches the other end - can anyone help?
Hi ,
It is glad to hear that your problem is resolved.
Please rate it.
satish
14 Replies 14
rwyates_2
I am guessing the is a point to point serial link. So you will need one end to provide clocking for the ling. On the host you will need to put clock source to internal.
Here is a link that explains that.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1826/products_feature_guide09186a0080080f74.html
Adam Frederick
Level 3
Level 3
Can you post a "wr t" from both routers?
Also a "show controllers" from both routers if possible.
smothuku
Level 7
Level 7
Hi ,
T1 configuration example.
hostname RTR-A
controller T1 1/0
framing esf
linecoding b8zs
channel-group 0 timeslots 1-24
clock source internal
check the status of T1 interface using ""sh controller T1 1/0"".
Configure the serial interface and check the status.
If the problem persists then take telco help to resolve the issue.Most probably it is problem with line not a router.
satish
Wow - thank you everyone for your help on this issue - here is what I got from the "sh controller T1 1/3" command:
T1 1/3 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20041023, FPGA: 16, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Internal.
CRC Threshold is 320. Reported from firmware is 320.
Current port master clock: recovered from controller 1/1
Data in current interval (465 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 1:
Data in Interval 2:
Data in Interval 3:
Data in Interval 4:
Data in Interval 5:
Data in Interval 6:
Data in Interval 7:
Data in Interval 8:
Data in Interval 9:
Data in Interval 10:
Data in Interval 11:
--More--
Hope this helps?
Hi ,
Thanks for your info.. I think there is no problem with config of T1 as it is showing Up.
Is it possible to get the config of both serial interfaces ?
Satish
I can only get the info for this router for the time being. In doing the "wr t" I do see a setting that is different from the other interfaces:
controller T1 1/2
framing esf
linecode b8zs
channel-group 0 timeslots 1-24 speed 64
controller T1 1/3
framing esf
linecode b8zs
channel-group 0 timeslots 24
The "clock source internal" is not listed in any other interface but the one that does not work properly. How do I set it to read "framing esf"?
Hi ,
Can you remove clock source internal from controller T1 1/3 and check the stauts of T1 1/3 and serial interface.
Satish
Here is the config of the other router:
Serial1 is up, line protocol is down
Hardware is PQUICC with Fractional T1 CSU/DSU
Internet address is 192.168.98.1/30
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
Encapsulation PPP, loopback not set
Keepalive set (10 sec)
LCP Listen
Closed: IPCP, CDPCP
Last input 6w6d, output 00:00:04, output hang never
Last clearing of "show interface" counters 1w0d
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
1372 input errors, 392 CRC, 734 frame, 0 overrun, 0 ignored, 246 abort
121929 packets output, 1707006 bytes, 0 underruns
0 output errors, 0 collisions, 32516 interface resets
1 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
Hi ,
It is possible to do hard lookback test on both ends ?
satish
Hi ,
Can you change the channel group 0 time-slots 24 under T1 1/3 to channel group 0 time-slots 1-24.Below link is useful for troubleshooting T1 and serial line problems.
http://www.cisco.com/en/US/customer/tech/tk713/tk628/technologies_tech_note09186a00800a758d.shtml#topicd
You configured channel group 0 time-slots 1-24 under T1 1/2 means you can see one serial interface i.e 1/2:0 where as you configured channel group 0 time-slots 24 under T1 1/3.
Can i know the difference between these two ?
According to me if you want to use 24 serials lines of T1 then you need to configure channel group 0 time-slot 1 for first channel and channel group 1 time-slot 2 for 2'nd ..etc..
If i am wrong correct me.
satish
If it is s full T1 he needs
chan group 0 timeslots 1-24 speed 64
Hi ,
Thanks for your info ..I know it..but what is the signicance of channel group 0 time-slots 24.
satish
Satish, you are the man. You directed me to the right spot, the internal clock and time slot were both the issue and this issue is now resloved. The line and protocol are both up and running.
Thank you very much
Hi ,
Please rate it.
satish
