How to connect and configure connectivity between two remote-sites with the same subnet?
liv.manole1
Hello guys,
I have a client who wants to have the same subnet in his HQ and also in the DR remote-site...I cannot seem to find the way to do that...he only provides the L2MPLS tunnel between two ASR routers where I will connect. I attached the generic topology...bascically the ideea that a virtual machine from HQ with IP 10.1.0.7 could be moved to DR remote-site keeping the IP. I cannot manage a solution in which the the VM keeps the IP with the same gateway..can R1 and R2 be configured in HSRP somehow?...is there a NAT I have to configure on R1 and R2? (i don't have access to the routers on which the L2MPLS is configured...
Please help...any solution or sugestion is helpful
Thank you
Giuseppe Larosa
Hello @liv.manole1 ,
the ASR routers should be able to support bridge domains in this way you can build a single broadcast domain including the L2 MPLS link between them and their respective LAN facing interfaces.
At the moment I cannot find a good link about it.
see
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/configuration/guide/chassis/ce-xe-3s-asr1000-book/ce-ether-vc-infra-xe.html
If between the two devices there was a L3 internetwork you could use OTV
Hope to help
Giuseppe
