How to connect Single cisco router to split the network
My Problem is
I have single Cisco 1800 Router
I want to connect office to site
My office LAN ip : 192.168.0.x/24
Site LAN ip is 192.168.169.x/24
Please post full set of configuration.
As i understood you want to make these 20 PCs able to reach the office which you have a Cisco router there. but the subject made me confused (How to connect Single cisco router to split the network).
Anyway, if you need to connect both sites together and you only have one router at the office, you can either use your ISP to buy a VPN connection between both site & office (which will cost alot). or you can just buy one puplic IP address and use it in your cisco router, so that all PCs can establish PPTP connections with that router which will allow you to connect both site & office together. if that what do you need, please tell me in order to support you with needed configurations. unless, kindly clarify.
9 Replies 9
cadet alain
you can do a site-to-site IPSec VPN but you'll need a remote router for the other site.
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080093f73.shtml
Regards.
Alain
M-Hassanien
Hi Naresh,
can you please tell what is the type of router & IOS (if cisco) you do have in both site & office?
In my site office I have 20pcs. At present i hav connected through 3com wireless bridge 2 bridge. I have one cisco 1800 router. In office. How can I route wan & LAN so that I can separate d network
Rgds
Mohammed Hassanien
I highly appreciate your support. I do have static IP from the ISP so please help me to configure that. So that site people can connect our office through VPN.
My cisco router is 1800-1840
Pls note: my network is like this
ISP->Fortigate firewal-->Core Switch
Regads
On Cisco Router (PPTP Server):
interface Serial0/1/0.87 point-to-point
ip address X.X.X.X 255.255.255.252   <== Static (public) IP with ISP
snmp trap link-status
frame-relay interface-dlci 87
interface FastEthernet0/0                  <== Private IP (Your Office LAN)
ip address 10.4.92.1 255.255.255.0
duplex auto
speed auto
aaa new-model
aaa authentication ppp AUTH local
aaa authorization exec AUTH local
vpdn enable
vpdn-group 1
accept-dialin
  protocol pptp
  virtual-template 1
username cisco privilege 1 password cisco
username test privilege 15 password test
interface Virtual-Template1
ip unnumbered Serial0/1/0.87                  <== WAN Interface (with static IP)
peer default ip address pool VPDN
no keepalive
ppp encrypt mppe 128                             <== For Data Encryption (Using  Microsoft Point-to-Point Encryption)
ppp authentication ms-chap ms-chap-v2    <== You will use these while creating PPTP connection at client PC
ip local pool VPDN 10.4.92.100 10.4.92.200   <== Private IPs range which will be allocated to client PCs
On Client PC at site:
Please follow this link:
http://doc.m0n0.ch/handbook/pptp-windows.html
but kindly change the security settings to be as that image (in order to pick just ms-chap & ms-chap-v2)
You can also make a NAT in order to let these PCs to reach internet from that static IP in the office. If you are interested, please let me know in order to support you with the needed configuration "God Will".
Waiting your feedback.
Mr.Mohammed Hassanien Thank you so much let me try. I will update you once again thanks a lot. tc
Dear Mr. Naresh,
It is my pleasure to serve. And i am here for any further details .
Hi Mohammed,
Thank you so much one more help needed step by step configuration for below connectivity.
Please find attached image.
router1: f0/0 192.168.0.64     f0/1: 192.168.166.101
3com bridge1 : 192.168.166.102
3com bridge2 : 192.168.166.103
router2: f0/0 192.168.169.64  f0/1: 192.168.166.104
Please note that from Office1 to Office2 I want to access all computers but from Office2 to Office1 they have to access only 2 servers i.e 192.168.0.177(app server) and 192.168.0.58(database)
regards
regards
