How to delete IOS image inside 3600 router
trinawong
Hi,everyone
There is a 3600 router, and inside has 2 IOS image, now I would like upgrade the IOS image file, but there is not enough space, so I deleted one IOS image, but after that when I 'show flash', the IOS image which i deleted just marked 'deleted' behind the IOS name, the total used size still include this one, after I reloaded the router, still the same situation.
Is anyone can give me some idea how to permanently erase the IOS image for 3600 router?
Thanks a lot in advance.
Trina
thomuff
Level 3
Level 3
I believe you have to squeeze it.
Here is a TAC solution that explains the squeeze.
Router#squeeze flash:
http://www.ciscotaccc.com/core/showcase?case=K19979276
Hi, guys
Thanks for your reply.
But for this serial router doesn't support 'squeeze' command.
Any comment?
Thanks a lot.
jdilley
If you cannot issue the "squeeze flash:" command, you could try to format the flash ("format flash:") and then re-upload the IOS to the router's flash memory. What IOS are you running? What kind of 3600?
