How to dual stack cisco X3750 switch
rfuentes1111
Hi Team,
I have a Cisco Switch 3750 in production but i need to add a second switch as stuck switch can I do it while is in production or Do I need to shut down the switch.
Also do i need to do any configuration after been install thank you team.
Reza Sharifi
Follow this link to add the new switch.
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/71925-cat3750-create-switch-stks.html#anc16
Joseph W. Doherty
Could you expand on "stuck switch"?
Leo Laohoo
The new member switch must be powered off BEFORE attaching any stacking cables.  Failure to do so will force the existing stack to reboot (this is by design).
