how to find the host based on IP address
UCBNOCWAN
i have host connected to port on my swtiched network, please let me know on which and which post the host is connected
Host ip:10.1.89.50
1 step:
core720#p 10.1.89.50(host IP)
Sending 5, 100-byte ICMP Echos to 10.1.89.50, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
core720#
step 2:
core720#sh arp | in 89.50
Internet 10.1.89.50 0 0050.564b.65b6 ARPA Vlan90
step 3:
core720#sh mac-ad
core720#sh mac-address-table | in 0050.564b.00b6
* 90 0050.564b.65b6 dynamic Yes 0 Po10
core720#
please guide me from here to locate the on which switch the host(10.1.89.50) is connected
Giuseppe Larosa
Hello UCB,
I would go on in this way that I use:
a) core720# sh ethercha sum
find the member links of Po10
let's suppose it is Gi4/1 a member link of Po10
do
b) sh cdp n g4/1
you find an hostname of next switch
c)
telnet to that switch by name or ip address
d) do
sh mac-address-table address 0050.564b.00b6
do sh cdp n of the interface listed in the output of previous command:
if no cdp neighbor is found or an IP phone is found the search is terminated
otherwise repeat steps c) e d)
Hope to help
Giuseppe
Dear All,
still i am unable to locate plz find the output
core720#sh etherchannel su
1 Po1(SU) - Gi1/1(P) Gi1/2(P) Gi6/1(P) Gi6/2(P)
10 Po10(SU) - Gi1/21(P) Gi1/22(D)
11 Po11(SU) - Gi1/23(P) Gi1/24(D)
21 Po21(SU) - Gi8/1(P) Gi8/2(P)
50 Po50(SU) - Gi1/5(P) Gi1/6(P)
51 Po51(SU) - Gi1/7(P) Gi1/8(P)
52 Po52(SU) - Gi1/9(P) Gi1/10(P)
53 Po53(SU) - Gi1/11(P) Gi1/12(P)
core720#
core720#sh cdp ne gi1/21 de
Device ID: 3750-VC-2
Entry address(es):
IP address: 10.1.128.101
3750-VC-2#sh mac-address-table | in 0050.564b.65b6
90 0050.564b.65b6 DYNAMIC Po41
3750-VC-2#sh eth
3750-VC-2#sh etherchannel su
w - waiting to be aggregated
d - default port
Group Port-channel Protocol Ports
10 Po10(SU) - Gi1/0/49(P) Gi1/0/50(D)
11 Po11(SD) - Gi1/0/51(D) Gi1/0/52(D)
31 Po31(SU) LACP Gi1/0/1(P) Gi1/0/2(P) Gi1/0/3(P)
32 Po32(SU) LACP Gi1/0/5(P) Gi1/0/6(P) Gi1/0/7(P)
41 Po41(SU) LACP Gi1/0/41(P) Gi1/0/42(P) Gi1/0/43(P)
42 Po42(SU) LACP Gi1/0/33(P) Gi1/0/34(P) Gi1/0/35(P)
3750-VC-2#sh eth
BRA-R8-3750-VC-2#sh etherchannel su
Flags: D - down P - in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
u - unsuitable for bundling
d - default port
Number of channel-groups in use: 6
Number of aggregators: 6
3750-VC-2#sh cdp ne gi1/0/41 de
3750-VC-2#sh cdp ne gi1/0/42 de
3750-VC-2#sh cdp ne gi1/0/43 de
3750-VC-2#
Hello UCB,
out Po41 formed by Gi1/0/41(P) Gi1/0/42(P) Gi1/0/43(P) and using LACP you probably have a server with multiple NICs using teaming
your search is terminated
0050.56 OUi :
00-50-56 (hex) VMWare, Inc.
005056 (base 16) VMWare, Inc.
44 ENCINA AVENUE
PALO ALTO CA 94301
UNITED STATES
This is a VMware system with 3 NICs in bundle
Hope to help
Giuseppe
