How to find the ios in CIsco website?
wfqk
Level 5
Level 5
Hi we want to upgrade asr ios. Anyone can give me suggestion how to find the ios in Cisco website?
Here is ios asr1000rp2-adventerprisek9.03.13.03.S.154-3.S3-ext.bin
Thank you
Hello showipinterface,
Only mouse over the "Support" link to display the options.
ASR 1000 Series Route Processor (RP2)
I hope this helps.
Best Regards.
Thank you for your reply. but i have not found the ios and
asr1000rp2-adventerprisek9.03.13.03.S.154-3.S5-ext.bin
Please try clicking on the "> All Releases" section which is on the menu located at left side of the Download Software site. There, the releases are ordered hierarchically. The particular release you are looking for should be located on:
> All Releases
   > 3
      >3.13S
         >3.13.3S(ED)
I hope this helps.
Best Regards.
