How to force DynDNS update
bradlesliect
How do you force a DynDNS update on a cisco router without dropping the connection?
Is there a clear command I can use from CLI? Using a Cisco 877W ADSL Router.
rajivrajan1
Level 3
Level 3
Hi Bradlesliect
update dns with time interval could help you.
gothrough this document.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5413/products_feature_guide09186a00802a1b9c.html#wp1170826
rate if it helps
Thanks for link but it doesn't solve my problem. I need to refresh DynDNS on the router without having to drop the client's line.
You may don't like this answer, but I personally think it's easier to manage the dyndns updates installing a client on one of the host pc.
On the client software, the default detection in web (web page) which make this compatible with nat.
how would i edit this to include time intervals?
HTTP
add http://@members.dyndns.org/nic/update?system=dyndns&hostname=&myip=
remove http://@members.dyndns.org/nic/update?system=dyndns&hostname=&myip=
