10-23-2020 04:39 AM
Hi Community,
I dont know how to configure network G to get a dynamic ip from router 4.
The path most be on the L3 switch and then DHCProuter 4 (see picture).
Who can help me?
Solved! Go to Solution.
10-23-2020 05:15 AM
You need to extend the VLAN in switches to get IP address from Router (where i belive you have DHCP running)
here is example :
10-23-2020 05:15 AM
here is example :
10-23-2020 07:32 AM - edited 10-23-2020 07:39 AM
I did, pc1 and pc2 get a DHCP ip from the router.
Thank u
