How to Increase VDSL Upstream Power Level
Scott Pettit
Level 9
Level 9
We've got a customer with an 887VA who is on VDSL2 and is experiencing very poor upstream sync rates.  Downstream sync rate is good.
Looking at the modem stats the upstream power level looks really low, only 3dBm.
Are there some commands I can insert under the controller configuration to force the power level higher?  We used to be able to do this on the 877's with ADSL.
(config-controller)#?
Controller configuration commands:
  bitswap      Bit swap
  default      Set a command to its defaults
  description  Controller specific description
  diagnostics  Diagnostics DELT
  exit         Exit from controller configuration mode
  firmware     Active firmware file name
  help         Description of the interactive help system
  modem        vdsl modem configuration
  no           Negate a command or set its defaults
  operating    Configure auto or specific VDSL operating mode
  shutdown     Shutdown vdsl controller
  sra          Seemless Rate Adaption
  sync         xDSL sync preferences
  training     Dsl firmware training log
Here are the line stats:
Attainable Rate:          18272 kbits/s                     560 kbits/s
Actual Power:                     12.7 dBm                      3.3 dBm
Per Band Status:                 D1           D2           D3           U0           U1           U2           U3
Line Attenuation(dB):   24.2          74.6          N/A          N/A          59.8          N/A          N/A
Signal Attenuation(dB): 24.2          74.6          N/A          N/A          57.2          N/A          N/A
Noise Margin(dB):       12.4          0.0          N/A          N/A          11.9          N/A          N/A
jmakepeac
We have similar numbers on a 2911 router with an ehwic-va-dsl-a:
Attainable Rate:        14600 kbits/s            462 kbits/s
Actual Power:             9.2 dBm                 5.9 dBm
Line Attenuation(dB):   27.7    89.4    102.3   8.9     68.6    64.7    N/A
Signal Attenuation(dB): 27.7    N/A     N/A     8.9     0.0     0.0     N/A
Noise Margin(dB):       6.3     N/A     N/A     5.4     N/A     N/A     N/A
We figured it was just line conditions, we're about 1000m from the street cabinet but still think upstream could do better.
