How to know the current throughput?
conectividade
Hi folks!
I would like your help. How can I do using CLI, to know the current throughput of 2691 router?
I know that max throughput is 28Mbps and 70000 pps.
thanks in advance,
Renato
pkhatri
Level 11
Level 11
HI,
There is no easy way to do so. One possible thing you can do to get an estimate is to get the input rate on each interface (using show interface), sum up all of these input rates and then divide it by two.
Hope that helps - pls do rate the post if it does
Paresh
