How to limit bandwith per interface Vlan on trunk
rayle_alive
Hi Guys, my question regarding QoS Police.
I have 7609 router (PE) connected via 1Gb fiber to 6524 switch(CE) using dot1Q trunk. The customer is having VlanA, VlanB & Vlan C.
The problem is I have to limit 100Mbps bandwidth for each Vlan on the PE-CE trunk. What command do I need to set on 7609 router? (assuming no additional command needed for CE)
network.king
Level 4
Level 4
6500 switch and 7600 router , we can use a similar policy map to limit the traffic .
Create three class-maps for each customer and match the customer ip addresses in indivual class-maps
configure a policy-map and call the class-map to policy-map and police each class bandwidth to the requirement.
or create individual policy-map for each vlan
Apply the policy map to the Vlans .
Just a addition , configure " mls qos vlan-based " under the Gig interface
A link for ref:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801c8c4b.shtml#ios
hope it helps
regards
vanesh k
