how to make Vlans talk to each other on two separate network? Vlan 10 and Vlan 20
jamesidk41403
Im doing this from a packet tracer. I uploaded my packet tracer. Thanks for the help.
the routing on your routers is incorrect. You have several options:
Static default route on both routers:
Router2
ip route 0.0.0.0 0.0.0.0 192.170.1.2
Router3
ip route 0.0.0.0 0.0.0.0 192.170.1.1
or (on both routers):
router rip
version 2
network 0.0.0.0
or
router eigrp 1
network 0.0.0.0
7 Replies 7
Router2
Router3
router rip
version 2
network 0.0.0.0
or
router eigrp 1
network 0.0.0.0
thanks computers are now talking to each other. how come the phones cant call each other?
Hello
@Georg Pauwen wrote:
Router2
Router3
I would not advise the above, Having default routes pointing directly to each other is asking for trouble, If this was on a production site it could cause a lot of issues basically what you are doing here is introducing a routing loop.
If any host from either side trys to reach a network that its local rtr isnt aware of then the rtrs will push it towards their own default nexthop so then they will continually send it to each other thus a loop is created.
@jamesidk41403  As for you topology you have the same subnets running on both rtrs which isn't applicable
Using RIP is okay but suggest disable auto summerization  and use version 2 rip and remove the above default routes.
See the  revised PT file (attached)
Kind Regards
Paul
thank you. it worked. sorry for the late reply was busy
thanks
The phones are talking ? You added the dial peers on both sides ?
yes i figured out i need to add dial-peers to them. thank you
