How to map RMAC to Real MAC Address in end station
w.wichatrong
CIP-Slot1#llc badns
pcep=0085 rmac=0068.e83a.219f lmac=4000.7206.1111 rsap=04 lsap=04 this=81F609D8
rif=0810.1F91.BB81.3E80.0000.0000.0000.0000.0000 ack-len=0000
This Command running on cisco 7200
End station is IBM mainframe
Giuseppe Larosa
Hello Worapun,
when going through a SR/TLB (Source Route Translational) Bridge between an ethernet segment and a token ring segment the order of bits inside each octet is reversed.
If this is the case the OUI
0068e8 that doesn't have a match in OUI page has to be read
00 = 00
68 = 01101000 rollover = 16
e8 = 11101000 rollover = 17
or it can be the result of an administrative settings
see
http://www.cisco.com/en/US/docs/ios/bridging/configuration/guide/br_remote_srb_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1002863
you can find information about conversion between llc2 TR and ethernet frames.
Hope to help
Giuseppe
Thank you Giuseppe
