How To move NTP From Server to Switch
Irvan Lubis
How to move NTP from server to Switch? how to configure in switch ? ThankYou
M02@rt37
Hello @Irvan Lubis
If you want the switch to act as an NTP server and provide time synchronization to other devices, you need to configure it as an NTP server.
Under configuration terminal:
ntp master <STRATUM-LEVEL>
"NTP uses stratums to define how far away from an atomic clock a given NTP server is. A device getting it’s time directly from an Atomic Clock is said to be stratum 1. A device getting its time from a Stratum 1 server is a Stratum 2, or 1 hop away. The stratum is important because using the stratum NTP can make corrections and align itself more closely with an atomic clock, so that regardless of the stratum level your device is getting it’s time from all devices will be within milliseconds of one another, and that’s some pretty accurate time!" (Source: https://blog.noblinkyblinky.com/2023/07/07/configuring-ntp-on-a-cisco-device/)
Best regards
5 Replies 5
M02@rt37
Hello @Irvan Lubis
Best regards
How to connect NTP from server to switch? is there a configuration? after configure master NTP
@Irvan Lubis
If you want your serve to be SYNC (NTP) on your Swtich, configure on server as NTP server an IP hosted on your Switch.
Your server need to communicate with this IP.
Best regards
Irvan Lubis
c
ip ntp server <the server provide the NTP to SW>
ntp master 5 (5 or more depend of st of server)
that what you need
note:- if the server use Auth you need to add command to SW
Thanks A Lot
MHM
