11-13-2023 01:49 AM - edited 11-13-2023 03:01 AM
Can you help me figured out what's the problem here? Because i can't ping all the pc and the server i configured all the router and all of them is good.
Solved! Go to Solution.
11-13-2023 02:06 AM
Check all PC and servers Gateway !
As example on PC0:
Gateway must be on the same subnet as the IP.
Other thing, you have a configuration problem between routers and their respective L2 switch!
Configure a Trunk on Switch side, on the interface facing the Router.
Configure a sub-intefrace on routers, on their interface facing the Switch; this is called Router On A Stick: https://ciscotracer.wordpress.com/2015/03/27/routage-inter-vlan-partie-12-router-on-a-stick/
11-13-2023 02:11 AM - edited 11-13-2023 02:13 AM
Example for Switch0 and Router Ejay interfaces:
Modify IP Gateway of PC0, put 192.168.1.14 (IP Gw hosted by Router Ejay)
Ping your Gw as a test:
-- Re check ALL IP gateway on all PC
-- Re configure Switch1-2-3 interfaces facing their Routers like the example.
-- Check the Server0 IP Gateway an the Franiel router configuration also
11-13-2023 02:48 AM
11-13-2023 02:06 AM
As example on PC0:
11-13-2023 02:48 AM
