How to NAT
munawar.zeeshan
I have a cisco router at my gateway.My internet bandwidth is terminated on it.I have 2 servers in my LAN which i want to access from outside. For this i have statically NATed them using a public IP at router.Now i also want to allow my internal host (with local IPs) to acccess internet. For this can i define one more nat too ?? In this scenario my two interfaces of router i.e Internal and Exteranl will be having both IP NAT INSIDE and IP NAT OUTSIDE statement.Will it serve the purpose ?
cisco24x7
Level 6
Level 6
inteface F0/0
description Internet interface
ip address 1.1.1.1 255.255.255.0
ip nat outside
interface F0/1
description LAN interface
ip nat inside
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
ip nat inside source list 100 interface F0/0 overload
ip nat inside source static tcp 192.168.1.0 3389 interface FastEthernet0/0 3389
ip nat inside source static tcp 192.168.1.11 22 interface FastEthernet0/0 22
Easy right?
csco10716389
The IP nat inside will be configured over the WAN interface for incomming traffic from internet and IP nat Outside should be configured over your ethernet or LAN interface connected for out going interface from LAN.
Better u creat a pool of ip for ur lan Ussage.
sdoremus33
Level 3
Level 3
Pooled mode is nother option it uses hosts in the private network thst use a pool op public addresses that are available for x number of hosts
Ex:
Pool of 3 addresses
Once the first available id takne then the NAT table allocates the next ip address in the pool for the user until the address is relinquished
