How to prevent the Output drops in cisco router serial interface
anijohn1980
I am very new to the support community, I am facing one issue, in my router serial interface output drops are more,  link speed is 2 Mbps, even in off peak hours also output drops I can see, Can some one give me a solution to the same apart from increasing the bandwidth.
Thanks in advace.
Ani John
6 Replies 6
Reza Sharifi
Hello Ani,
You may have a bad cable or problem with your CSU/DSU.
If input errors are accumulating on both ends of the connection, clocking of the CSU is the most likely problem.
If only one end is experiencing input errors, there is probably a DSU clocking or cabling problem.
Please refer to this document for more info on how to troubleshot serial interfaces:
http://www.cisco.com/en/US/docs/internetworking/troubleshooting/guide/tr1915.html
Reza
Incorrect, oputput queue drops are only and exclusively cause by congested interface.
Giuseppe Larosa
Hello Ani,
from a telnet session you can copy the text and you can paste it in a text file making reading easy even if you use OS shell you can do this.
about your problem you may need to add outbound shaping  because you can have burst of traffic that fills output queue and that causes the output  drops.
Hope to help
Giuseppe
Phillip Remaker
Drops are a normal reaction to link overloading - are you sure you don't have any traffic running around the clock that is naturally bursty (e.g. Bittorrent)?
It might be interesting to enable Netflow and analyze the traffic patterns.
Hey Ani,
Output drops are caused by a congested interface. For example, the traffic rate on the outgoing interface cannot accept all packets that should be sent
out. The ultimate solution to resolve the problem is to increase the line speed. However, there are ways
to prevent, decrease, or control output drops when you do not want to increase the line speed.
You can prevent output drops only if output drops are a consequence of short bursts of data.
If output drops are caused by a constant high-rate flow, you cannot prevent the drops.
Here is a reference link for the same:
Troubleshooting Input Queue Drops and Output Queue Drops
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080094791.shtml
However, please check that you are not getting Layer 1 errors like Input Errors, CRCs, aborts on the Serial Interface itself.
If we are getting that, it would indeed cause the drops to accelerate.
In case, if the Layer 1 errors are coming up , try the following:
#Swapping the Cable with a good known one
#Swapping off the WIC card in question.
Hope that helps!
Rishika Goel
OP included show interface, there are no layer 1 errors.
Incorrect, layer 1 errors DO NOT cause queu ouput drops
Incorrect, the most common cause of layer 1 errors is faulty circuits, not router cards.
