06-12-2022
08:48 AM
- last edited on
06-14-2022
03:16 AM
by
Translator
BGP ↔ OSPF redistribution is not possible.
We are not advertising BGP globally, so we are trying to redistribute it in VRF.
How do I redistribute?
I have attached the config and routing information as attachments.
router ospf 100
router-id 10.40.98.1
redistribute bgp 65000
network 10.40.98.0 0.0.0.3 area 0
network 10.40.98.4 0.0.0.3 area 0
default-information originate
Fusion(config)#router bgp 65000
Fusion(config-router)# address-family ipv4 vrf OFFICE_VN
Fusion(config-router-af)#redistribute ospf 100
%VRF specified does not match this router
Solved! Go to Solution.
06-12-2022
08:55 AM
- last edited on
06-14-2022
03:18 AM
by
Translator
Becuase the opsf is not vrf aware and you redistreibte it under ipv4 bgp (bgp vrf aware) this config is wrong.
You need to config opsf with vrf aware
Ip router opsf vrf x
Then you can redistrubte it under bgp address family.
06-12-2022
08:55 AM
- last edited on
06-14-2022
03:18 AM
by
Translator
06-12-2022
11:39 PM
- last edited on
06-14-2022
03:18 AM
by
Translator
router ospf 100 vrf OSPF_vrf
router bgp 65000
bgp router-id 10.200.35.1
address-family ipv4 vrf OSPF_vrf
bgp aggregate-timer 0
network 10.40.98.4 mask 255.255.255.252
exit-address-family
ip route vrf OSPF_vrf 0.0.0.0 0.0.0.0 10.40.98.6
vrf definition OFFICE_VN
rd 1:4099
address-family ipv4
route-target export 1:4099
route-target import 1:4099
route-target import 65000:3
route-target import 65000:1
route-target import 65000:2
route-target import 100:100
route-target import 65000:4
exit-address-family
vrf definition OSPF_vrf
rd 65000:4
address-family ipv4
route-target export 65000:4
exit-address-family
06-12-2022
12:46 PM
- last edited on
06-14-2022
03:20 AM
by
Translator
Hello @JustTakeTheFirstStep ,
as noted by @MHM Cisco World you need to have an OSPF processed associated to the VRF and the VRF needs to be defined on the node otherwise you get the error message:
I understand this is the Fusion router of an SD access solution and it is the "ASBR" or exit point from the SD Access campus fabric to outer world. In any case the ospf process needs to be manually configured and mapped in the VRF.
You have:
rd 1:4099
address-family ipv4
exit-address-family
rd 65000:4
You may need an OSPF process for each VRF ( VN in SD access terms or macro-segmentation ) you need to think of the Fusion router as a multi VRF CE in MPLS L3 VPN context.
Be aware that the DN bit is set for VRF aware LSAs.
Hope to help
Giuseppe
