Some Questions about Good Old C6500-E
Peyman Zadmehr
Hi everybody
I know this is a little bit odd to ask these questions, But these questions are somehow important to me. Would you please help me in this regard:
1- I am considering using RSP720 on Cisco 6500-E. I could not find any technical notes about supporting this card on C6500. I want to know is RSP720 supported on C6500-E or not? The other way around is applicable.
2- No matter whether the RSP is supported or not I want to Use EoMPL over GRE while using RSP720(C7600 or C6500). I want to ask if this feature is supported or not and does it work in relatively high volumes of traffic(for example 2Gbps!!)
Thank you for your help and support.
Peyman
marce1000
 - You can't use that card or a router processing card on the 6500-E , see for instance : https://www.provantage.com/cisco-systems-rsp720-3cxl-ge~7CSC87EY.htm , look for The Following Are Compatible With Cisco Systems RSP720-3CXL-GE=
 M.
Dear Marc
Thank you for the answer. What about the second question?
The second question is actually for using RSP720 on C7600.
Thank you
Peyman
