How to replace a LINUX firewall
amisseri
Community Member
I have a hub site which was part of an aquisition, but is now completely trsuted. They have a linux firewall with 192.168.0.x LAN addresses, but are all 1 to 1 static natted to 10.161.0.x addresses. I need to figure out how to remove the linux fw with either a vlan or something, but be able to preserve the IP addresses at least until I can have all the devices change their IP to the correct addresses. There are a lot of apps using the natted IP addresses and not DNS. There are some using the non natted IP when accessed internally on the segment.
Can I put in a vlan with primary and secondary addresses for both old and new segments and just route it to my WAN?
albert.remo
Level 5
Level 5
Hi!
Good Day! That is a good idea or you may want to use the existing technology itself (NAT) less the security of a firewall.
Please see link below for reference:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml
Hope this helps.
Albert
