How to reset default factory command on ASA ,Router and Switch
rechard_david
Dear All,
I would like to ask you about how to reset default factory on ASA,Router and Switch ( i mean it similar wr erase but if we do command wr erase all the command is gone, so i would like to original command on product.
Best Regards,
Rechard
mmacdonald70
The only way to reset the ASA to factory defaults is with the "wr era" command or the "clear configure" command.
If these commands are not available due to a password issue (ie can't remember the enable password) you will need to reset the passwords:
http://www.cisco.com/en/US/docs/security/asa/asa71/configuration/guide/trouble.html#wp1058131
hobbe
Level 7
Level 7
ASA
conf t
configure factory-default
Router: I dont know if there is such a command.
might be depending on model of router and software version.
so wr er and then reload is the closest I know off
Switch:
I do not know of such a command, might exist depending on model and software version
so wr er and then do a reload is the closest I know of.
Good luck
Hello, on a Cisco ASA from enable mode:
(config)# configure factory-default
Enter and there you go!
Hello
ASA
conf t
reload save-config noconfirm
Switch
write erase
delete flash:vlan.dat
reload
Kind Regards
Paul
