How to restart a process?
bellocarico
Is is possible to restart a single process (e.g. ospf) other than reload the router?
pkhatri
Level 11
Level 11
You cannot manipulate specific processes directly. However, you can use IOS-provided clear commands e.g.
clear ip ospf process
Alternatively, you can do something like this:
no router ospf
router ospf
You simply have to find the commands enabling the process and then delete and re-issue them.
Hope that helps
Paresh.
