How to run ISDN data and voice calls thru E1 (1 port) Multi-Flex Trunk WAN daughter card ?
vistaprogrammer
Dear All:
i have (E1 (1 port) Multi-Flex Trunk WAN daughter card ) inside my WAN router 3845, and i want to run the voice outgoing calls and the incoming voice calls, basically i could run Data calls on this card , but regarding the voice  i did the dial peer and voice port configuration(my isdn number is 21817, five digits) :
network-clock-participate wic 1
network-clock-select 1 E1 0/1/0
card type e1 1
isdn switch-type primary-net5
trunk group isdn-pri-voice
 max-calls any 500
controller E1 0/1/0
 pri-group timeslots 1-31
 description *E1 Controller Voice / Data Configuration*
interface Serial0/1/0:15
 ip address 10.52.60.1 255.255.255.0
 encapsulation ppp
 dialer-group 2
 isdn integrate calltype all
 ppp authentication chap callin
access-list 198 permit ip any any
dialer-list 2 protocol ip list 198
voice-port 0/1/0:15
 timeouts interdigit 3
 timeouts call-disconnect 5
 timeouts wait-release 1
 connection plar 100301
 description 100301 is the internal extension that i want to forward the incoming voice call to
dial-peer voice 1001 pots
 description ---- ISDN Local (Branch Director)
 translation-profile outgoing remove809
 destination-pattern 80901[456]......
 port 0/1/0:15
 forward-digits all
dial-peer voice 1002 pots
 destination-pattern 80902[123].......
 port 0/1/0:15
 forward-digits all
dial-peer voice 1003 pots
 destination-pattern 80903[13]......
 port 0/1/0:15
 forward-digits all
dial-peer voice 1004 pots
 destination-pattern 80904[13]......
 port 0/1/0:15
 forward-digits all
dial-peer voice 1005 pots
 destination-pattern 80905[12].......
 port 0/1/0:15
 forward-digits all
dial-peer data 1 pots
 incoming called-number 21817
dial-peer search type data voice
when i am doing the voice call from different external telephone line , the debug for (isdn q931, ppp authentication, ppp negotiation) came with this result
modem problem Bearer capability not available(0x3A): b channel
the debug result :
*Dec 28 14:43:59.404: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x020C
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98385
                Exclusive, Channel 5
        Progress Ind i = 0x8283 - Origination address is non-ISDN
        Called Party Number i = 0xC1, '21817'
                Plan:ISDN, Type:Subscriber(local)
*Dec 28 14:43:59.404: ISDN Se0/1/0:15 Q931: Received SETUP  callref = 0x820C callID = 0x0007 switch = primary-net5 interface = User
*Dec 28 14:43:59.408: ISDN Se0/1/0:15 **ERROR**: accept_incoming_csm_call: modem problem Bearer capability not available(0x3A): b channel 4, call id 0x7
*Dec 28 14:43:59.408: %ISDN-6-DISCONNECT: Interface Serial0/1/0:4  disconnected from unknown , call lasted 0 seconds
*Dec 28 14:43:59.408: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x820C
*Dec 28 14:43:59.408: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x820C
        Cause i = 0x80BA - Bearer capability not available
how can i solve this issue please , the card support the voice calls ?
please help ?
6 Replies 6
change the interface Serial0/1/0:15 as below
no ip address
encapsulation hdlc
No ppp authentication chap callin
also please do a "show inventory" to see the card type
thank you for your reply
basically i need ppp authentication since  our remote branches use to connect to this card as backup data path , all remote branches are using Bri isdn with ppp authentication and they are working fine with this card as backup data path...but what's more i want to receive voice calls on this card and forward it to internal telephone extensions (we have cisco unified communication manager 6.1 )
regarding the show inventory
3845-1-Freezone#show inventory
NAME: "3845 chassis", DESCR: "3845 chassis"
PID: CISCO3845         , VID: V01 , SN: ----------
NAME: "c3845 Motherboard with Gigabit Ethernet on Slot 0", DESCR: "c3845 Motherboard with Gigabit Ethernet"
PID: CISCO3845-MB      , VID: V06 , SN: ----------
NAME: "WAN Interface Card - Serial 2T on Slot 0 SubSlot 0", DESCR: "WAN Interface Card - Serial 2T"
PID: WIC-2T            , VID: V01, SN: ----------
NAME: "One port E1 voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "One port E1 voice interface daughtercard"
PID: VWIC-1MFT-E1      , VID: V02, SN: ----------
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V03 , SN: ----------
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 3", DESCR: "2nd generation four port FXO voice interface daughtercard"
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64          , VID: V01 , SN: ----------
NAME: "One Port Channelized E1/T1/PRI with Integrated CSU on Slot 1", DESCR: "One Port Channelized E1/T1/PRI with Integrated CSU"
PID: NM-1CE1T1-PRI=    , VID: V01 , SN: ----------
NAME: "High Density Analog Voice Network Module on Slot 3", DESCR: "High Density Analog Voice Network Module"
PID: NM-HD-2V          , VID: V01 , SN: ----------
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 3 SubSlot 0", DESCR: "2nd generation four port FXO voice interface daughtercard"
NAME: "Four port FXS DID voice interface daughtercard on Slot 3 SubSlot 1", DESCR: "Four port FXS DID voice interface daughtercard"
PID: VIC-4FXS/DID=     , VID: 3.1, SN: ----------
As a Test do the voice calls work if you have it set as I suggested above? I must admit I never got voice and data to work off a single VWIC-MFT-E1 ( we went to ADSL as the backup). I know in the past our  service provider would only allow one or the other. that's why I would be interested to know if it worked set for voice only.
does it make any difference if you change "dial-peer search type data voice" to " dial-peer search type  voice data"
keep me informed how you go i am interested in this one!
Dear Richard :
thank you very much , your suggestion is in the place
i did the configuration for voice only and it works successfully
now what is the next step ....
from the CO(exchange) it came one line to the patch panel to the modem then E1 coaxial crossover to the VWIC-MFT-E1 , i have another VWIC-MFT-E1 card but i want to configure same line for data and voice ...
any suggestion regarding this case please?
As I said I never got this working! I have not found any configuration examples either. But you most probably need to try a few of the ISDN commands on the s0/1/0:15 interface
perhaps try "isdn incoming voice voice" to start with
