How to run multiple commands on Command Prompt in Packet Tracer?
J_T
I tried to run multiple commands simultaneously on Command Prompt of a PC on Packet Tracer using '&'.
e.g.
ping 10.0.0.10 & ipconfig
This command works on Windows cmd but not on Packet Tracer cmd. I also tried ';' but it didn't work either.
Martin L
PT is just a sim with limitations regarding PCs and IOS; probably u cannot do same things as u would in normal Windows PC.  many things are not the same or missing
Regards, ML
**Please Rate All Helpful Responses **
Martin L
Regards, ML
