How to set defualt source interface for all packets sent by Router.
franchi2015
Im using the NAT on a stick configuration (described here) because that´s how i connect to my ISP.  The problem is that i cannot ping public IPs without using the source command at the end of the ping, in my case the only way to ping a public IP is this way:
     ping 8.8.8.8 source loopback 0
That´s ok, but now i want to ping websites too, and thats not possible, everytime i try:
     Home_Router#ping google.com
     Translating "google.com"...domain server (8.8.8.8)
     % Unrecognized host or address, or protocol not running.
. Here is my running config:
 ip domain lookup
 ip name-server 8.8.8.8
 interface Loopback0
 ip address my.publ.ic.ip and.sub.net.mask
 interface FastEthernet3
 ip nat inside
interface FastEthernet4
 ip address 172.31.64.39 255.255.248.0
 ip nat outside
 ip access-list standard internet
 permit 192.168.1.0 0.0.0.255
 ip nat inside source list internet interface Loopback0 overload
Is there a way to achieve that?
Jon Marshall
At the config prompt do an "ip domain lookup ?"  and see if you have the option to specify a source interface.
Jon
Jon Marshall
Jon
Yes Jon, indeed it is. The complete command is
ip domain lookup source-interface <interface>
Thanks a lot!
