How to show packet size stats on ASR1002
bakaholic39
Hello!
I have an ASR1002-X and I want output like this
Or is there another way to display packet size statistics on ASR1002-X?
Thanks!
6 Replies 6
DanielP211
Hello!
I dont have a 1002-x at hand to test but could you try the command show platform hardware pp active interface statistics?
BR
****Kindly rate all useful posts*****
Hi Daniel
Thanks for reply. I tried, but it didn't seem to be what I wanted
I'll try to get my hands on a 1002-x and get back to you.
BR
Show controller ethernet-controller interface x/x
try above
MHM
I tried but this command is not available in ASR1002-X
Knonley
Try below cli
Show controller <interface> stats
RP/0/RP0/CPU0#show controllers HundredGigE0/0/2/1/0 stats
Mon Nov 3 17:02:40.496 IST
Statistics for interface HundredGigE0/0/2/1/0 (cached values):
Ingress:
Input total bytes = 13869836397351170
Input good bytes = 13869836397351170
Input total packets = 14026350487787
Input 802.1Q frames = 0
Input pause frames = 0
Input pkts 64 bytes = 15811325564
Input pkts 65-127 bytes = 1446438066012
Input pkts 128-255 bytes = 2558478578310
Input pkts 256-511 bytes = 248225325007
Input pkts 512-1023 bytes = 196295874550
Input pkts 1024-1518 bytes = 9464137054724
