how to sort Flexible Netflow
snarayanaraju
Level 4
Level 4
Hello - Can anybody help me to know why i am not able to see ""sort" or "filter" command.
I am not able to find the command "sort" or "filter" using "show flow monitor" command. when i issue the command i see as below
ROUTER#show flow monitor name FlowMonitor-1 cache ?
format   Specify cache display format
|        Output modifiers
<cr>
I am trying to use the command as as per configuration guide. But it is not found in the IOS 15.1(3)S1.
show flow monitor [name] monitor-name cache sort options [top [number]] [format {csv | record |
table}]
pwoll
These command options appear to be available only in certain IOS releases.  Use the Feature Navigator to find releases supporting Flexible NetFlow Top N Talkers.
