How to synchronize PIM-DR & HSRP Active router.
How we can synchronize PIM-DR & HSRP Active router.
5 Replies 5
paolo bevilacqua
Give the designated router an higher priority in each respective configuration.
I get your point, let me ellabroate my requirement in bit detail:
Suppose if the HSRP active changes due to some reason, at that time how should i syncronize my PIM-DR.
There is no "easy way". You can either do not be concerned, or build an EEM script to detect the change and reconfigure PIM.
Let me try working with EEM script, will get back to you in case of any issues. Thanks for your guidance.
