how to test Network Speed and unstable network
UCrypto
Hi ,
I am using Meg@pop service without internet service. But my network is very slow and unstable.
I don't know how to test how much network speed .I know ping test only.
Please help how to test is it local network issue or Meg@pop issue ?
How to test network bandwidth ?
6 Replies 6
Leo Laohoo
Use iperf and point to Singtel's DNS servers.
Hold on a minute ... I'm looking at previous threads you've created.
This Meg@pop service, are you using an 890 with crypto enabled?
Our network can't access internet.we use mpls L3 service.
So can I point to singtel?
End to end I can use iperf but how to know it is ISP issue or our side?
What router are you using?
How big is the WAN link?
Is WAN encryption/crypto enabled on the router?
UCrypto
I am using cisco c892 router.
I run bgp only no encryption .
Later I will put.without encryption end to to connectivity is very slow.
Our wan link is 70 mbps Meg@pop.How to check actual WAN link is 70 m or not
in Megapop service?
890 does not have the DRAM to support a full BGP table.
@UCrypto wrote:
Our wan link is 70 mbps Meg@pop.How to check actual WAN link is 70 m or not in Megapop service?
890 does not have the CPU to support >50 Mbps.
Can we accept partial route only?
I saw two route only in my bgp table.One is connected route and my remote
network.
Can I use summarize ?
Do you mean DRAM or memory?
